| Transducer Installation ? http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=48040 |
| Author: | mibrahim [ Sun Jun 16, 2013 4:35 am ] |
| Post subject: | Transducer Installation ? |
I have the 2013 PA14 with the Lowrance Ready feature and am planning on purchasing a Lowrance Elite 5 DSI Fishfinder/GPS. My question is what difference does it make of having the transducer installed under the boat in the Lowrance hatch vs having it installed directly in the water. Does it make a difference in the quality of the results? |
| Author: | Elgeebee [ Sun Jun 16, 2013 4:39 am ] |
| Post subject: | Re: Transducer Installation ? |
I use the Elite 5, and I installed it in the Lowrance-Ready system of my PA 14...the picture doesn't look any different to me vs. my friend's who's got the same model fishfinder installed in a scupper on his Jackson. |
| Author: | mibrahim [ Sun Jun 16, 2013 4:53 am ] |
Do you both have the DSI features? Would the DSI be inhibited in any way? |
| Author: | Flyfsh [ Sun Jun 16, 2013 8:24 am ] |
I have the DSI and it works great through the cover. Jim |
| Author: | Elgeebee [ Sun Jun 16, 2013 9:45 am ] |
Yes, my model is the Elite-5 DSI |
| Author: | mibrahim [ Mon Jun 17, 2013 12:37 am ] |
Do I have the option of using traditional sonar without the DSI feature on the Elite 5 DSI? I've been noticing a lot of reviewers indicate that they have trouble noticing individual fish on the FF screen while using the DSi. Are those claims valid? |
| Author: | salmontim [ Tue Jun 18, 2013 6:12 pm ] |
I have two PA's My PA 12 uses the Lowrance-Ready system. My PA 12 I mounted the transducer "Gooped" to the interior of the hull. The only difference I saw was the shoot through the hull took about 10 min to show an accurate water temperature. I have been working on submarine sonar systems for the past 40+ years. the plastic of the hull provides minimal signal reflectivity or attenuation. Its all very boring but it boils down to the speed of sound in a medium. When you see a fish on your fish-finder you are really seeing the air inside the fish Blatter, etc. A fish is like a human, mostly water. When you watch a movie with submarines being hunted the sonar actually get a returning echo off the air inside the submarine. Speeds of sound: saltwater 4800 FPS (feet per second); Steel 16,000 FPS; Air 1,100 FPS. Not sure what the speed of sound through plastic is, But the navy has been using similar products (plastic/fiberglass) they call them acoustic windows. One other thing I often hear people Ney saying on the process of using goop for mounting. I used it in my outback and it worked without any problems for six years... |
| Author: | C4PZL0K [ Thu Jun 20, 2013 8:37 am ] |
I have the elite 7 hdi with downscan mounted in the Lowrance ready scupper hole with no problems. Cool job salmontim, thanks for the insight. |
