| The two round foam pieces http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=49384 |
| Author: | 4xtreme [ Sat Sep 21, 2013 8:33 am ] |
| Post subject: | The two round foam pieces |
I have a 2014 pa 14 I came with two round foam peices that came with it .When I got it they were just floating arounf in the haul of the boat . Dose any one know were they go? |
| Author: | badbill [ Sun Sep 22, 2013 4:28 pm ] |
| Post subject: | Re: The two round foam pieces |
Post a picture. I have a 2014 PA14 and mine did not have them that I know off |
| Author: | mmiller [ Mon Sep 23, 2013 8:55 am ] |
Short ones are typically floor support. |
| Author: | jeffn777 [ Mon Sep 23, 2013 11:27 am ] |
On my P/A the two round foam pieces are floor supports that fit directly under the Vantage Seat, supporting the front legs. There is actually a groove in the top of the foam support that coinsides with a ridge on the underside of the floor. Jeff |
| Author: | Alphonse [ Mon Sep 23, 2013 7:58 pm ] |
Likely flotation and typically zip tied to scupper pipes. Don't think foam makes for good structural supports. Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 |
| Author: | islandspeed2001 [ Tue Sep 24, 2013 7:12 am ] |
jeffn777 wrote: On my P/A the two round foam pieces are floor supports that fit directly under the Vantage Seat, supporting the front legs. There is actually a groove in the top of the foam support that coinsides with a ridge on the underside of the floor. Jeff You are correct |
| Author: | 4xtreme [ Tue Sep 24, 2013 3:00 pm ] |
thanks I will check it out shoot out a picture. It would be helpful . |
| Author: | BigRedObsession [ Tue Oct 01, 2013 10:16 pm ] |
Wedge them in the hull under the seat area. You'll be good. |
