| 2012 steering shaft schematic? http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=49652 |
| Author: | Alphonse [ Thu Oct 24, 2013 9:07 am ] |
| Post subject: | 2012 steering shaft schematic? |
I have a new 2012 hull I just received from Hobie via my dealer. The steering is different than on my other boat it is replacing. I need a schematic on how the steering shaft and steering handle are configured. Does the upper roll pin that holds the steering shaft in place have a bearing surface under it such as a stainless steel washer? The hull was a replacement hull and didn't come with any documentation. I called the dealer (nice folks) and they suggested that I look on the website but it isn't there. I could call them back and they will call Hobie but it is likely quicker to find out here. Thanks for the help. |
| Author: | mmiller [ Thu Oct 24, 2013 12:02 pm ] |
| Post subject: | Re: 2012 steering shaft schematic? |
PA12 Assembly manual shows steering handle assembly on page 6. No washer. http://static.hobiecat.com/digital_assets/pro-angler-manual_rev120827.pdf |
| Author: | Alphonse [ Thu Oct 24, 2013 12:31 pm ] |
mmiller wrote: PA12 Assembly manual shows steering handle assembly on page 6. No washer. http://static.hobiecat.com/digital_assets/pro-angler-manual_rev120827.pdf Thanks Matt, but I am looking for info on a 2012 PA14 which has the second generation steering. The attached is for the third generation steering. |
| Author: | mmiller [ Thu Oct 24, 2013 2:46 pm ] |
I'm told that at one time we used a rubber washer between the roll pin and hull to add friction, have gone without it now. |
| Author: | Alphonse [ Thu Oct 24, 2013 3:21 pm ] |
Okay Matt, thanks. Via trial and error, I have discovered that if you put anything between the roll pin and the embedded brass fitting/sleeve it raises the tree up on the lower end of the steering shaft where the lines connect and binds the rotation. So bottom-line, simply let the roll pin ride the brass sleeve and possibly the hull. Mine is working smoothly now. |
