| Painting a pro angler http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=49820 |
| Author: | 23mako [ Fri Nov 15, 2013 7:54 am ] |
| Post subject: | Painting a pro angler |
Hello, I am looking to buy a pro angler was found a good deal on a PA 12. However, it is yellow. Is there anyway to paint these things in a reasonable fashion? Thank you in advance. |
| Author: | SRAces [ Fri Nov 15, 2013 10:22 am ] |
| Post subject: | Re: Painting a pro angler |
23mako wrote: Hello, I am looking to buy a pro angler was found a good deal on a PA 12. However, it is yellow. Is there anyway to paint these things in a reasonable fashion? Thank you in advance. Unless you're using it to hunt with, I cannot understand why you would not like the Papaya Yellow color. It probably provides the best color from a safety standpoint to be seen on the water by other boaters. Can it be painted? I would suppose so if you used a paint designed for application on a plastic surface. You would have to sand and prep it to paint it. And once the paint started to age or start flaking off or get scratched off, the PA would start to look bad. I wouldn't even consider painting a PA if I didn't like the color. I would find one in a color I liked versus going the route you are suggesting. Just my 2 cents... |
| Author: | Shimanoman [ Fri Nov 15, 2013 10:29 am ] |
X2!! |
| Author: | 23mako [ Fri Nov 15, 2013 10:49 am ] |
Thanks guys. I would be using it to hunt with so I was just curious. Thanks again for the info and I look forward to joining the club! |
| Author: | Ring King [ Fri Nov 15, 2013 2:43 pm ] |
I keep saying I'm going to paint at least the front hatch lid of mine with Plasti-Dip just to see if it will stick. I'm pretty sure it will. I have friends that spray their cars, wheels, and dashes with the stuff just for temporary changes in color. It wouldn't be permanent but that's okay by me. |
| Author: | badbill [ Fri Nov 15, 2013 3:20 pm ] |
X3 Sent from my iPad using Tapatalk |
Look into camp wraps Sent from my iPad using Tapatalk |
| Author: | Jude [ Sun Nov 17, 2013 10:30 pm ] |
You can make a cover out of burlap & attach a camo net to it....add a camo dodger and youre set |
| Author: | bruce19365 [ Mon Nov 18, 2013 9:07 am ] |
Check Cabela's (or probably BPS) website and search "camo netting". Several patterns and sizes that you could use to cover your yak when hunting, have a very visible yak for fishing, and none of the issues with paint. |
| Author: | dboyd101 [ Mon Nov 18, 2013 12:48 pm ] |
This video should pretty readily answer your question: http://www.youtube.com/watch?v=pvHpveAoV8M |
