| Plug 'n Play Downrigger set-up (V2) - 2014 PA14 http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=50004 |
| Author: | joeyb [ Mon Dec 09, 2013 8:07 am ] |
| Post subject: | Plug 'n Play Downrigger set-up (V2) - 2014 PA14 |
Was asked for some info on this set-up...so thought I would share it here. Downrigger set up on my 2014 PA14. - Frame made with 3/4” PVC. - Arrows indicate, (2) 1/2” foam rubber gaskets (from an old bicycle handlebar) - Nylon 1” strap with plastic clip/buckle. - (4) Bolts, washers and wingnuts. ![]() There is foam rubber glued to the underside of board (where it contacts PA hull) ![]() PVC sits on rubber rest: ![]() ![]() 1" adjustable strap goes around bottom seat rail: ![]() ![]() set-up below is used for trolling planer floats (off sides) and a regular float down the middle. ![]() Rigged 'n Ready (just add water) ![]() Link to the 2010 PA version: viewtopic.php?f=78&t=47241 Regards, JoeyB |
| Author: | badbill [ Wed Dec 11, 2013 5:27 am ] |
| Post subject: | Re: Plug 'n Play Downrigger set-up (V2) - 2014 PA14 |
Thank you! Sent from my iPad using Tapatalk |
| Author: | badbill [ Thu Dec 12, 2013 5:57 pm ] |
Joey are you a Hardcore guy? I noticed Stew Rat took a picture in your video. Sent from my iPad using Tapatalk |
| Author: | joeyb [ Sat Dec 14, 2013 7:18 pm ] |
badbill wrote: Joey are you a Hardcore guy? I noticed Stew Rat took a picture in your video. Sent from my iPad using Tapatalk I have fished the Hardcore Invitational on the Catawba and some Carolina Yakfish tourney's with Stew-Rat. |
| Author: | Salmax [ Sat Dec 21, 2013 4:12 pm ] |
love the set-up....fantastic job |
