| PA Carts http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=50425 |
| Author: | OL Sarge [ Fri Feb 21, 2014 9:52 am ] |
| Post subject: | PA Carts |
Hey Guys What are you guys using for carts? I heard the scupper carts can cause cracks/leaks. I do both sand and ramps when launching, Any and all info would be much appreciated. OL Sarge |
| Author: | islandspeed2001 [ Fri Feb 21, 2014 10:50 am ] |
| Post subject: | Re: PA Carts |
The scuppers are reinforced on the PA's. You shouldn't have any problems using the Hobie Trax cart. One thing you need to is to make certain the tires do not rub on the PA. |
| Author: | SteveK [ Fri Feb 21, 2014 7:46 pm ] |
Ditto, the Factory Wheeleez cart, make sure you add metal valve caps if you are going to be in the salt. No caps in the salt will destroy the Shrader valve in no time . Steve Bassyaks |
| Author: | Jambone [ Sat Feb 22, 2014 7:00 am ] |
I use the Hobie dolly. My dealer recommendedit over the scupper carts because of the weight of the Pro Angler. The dolly is very heavy duty. Sent from my Galaxy Note 10.1 2014 Edition |
| Author: | jokers10 [ Sat Feb 22, 2014 8:42 am ] |
They make the Trax 2.30 for the PAs. It is a bit more heavy duty that the standard Trax cart. Costs $25 more as well. But Hobie does not recommend storing the kayak on the cart. |
