| 6 mm Elastic cord with Tabs http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=50558 |
| Author: | Cdcraw550 [ Mon Mar 10, 2014 12:28 pm ] |
| Post subject: | 6 mm Elastic cord with Tabs |
Bassfriend posted this a while back, but I cannot find "shock" cords with the tabs on the end like the one pictured. Can anybody help me find these or did he likely make it? ![]() Please forgive the photo pirating! |
| Author: | svendawg [ Mon Mar 10, 2014 12:36 pm ] |
| Post subject: | Re: 6 mm Elastic cord with Tabs |
I think the ones you saw were DIY. I made some from my PA. I used nylon webbing to make the tabs and used a lighter to melt the ends of the tab so it wouldn't fray. I doubled the webbing over the elastic cord and sewed the webbing to the elastic cord with power pro braid (#30pound). After the tabs were sewn I used the point of my soldering iron to make the hole in the webbing for the bolt holes. You will need a strong needle and pliers to pull the needle through the webbing and cord. |
| Author: | Cdcraw550 [ Mon Mar 10, 2014 12:45 pm ] |
I would just have to pick up the shock cord, nylon webbing, and needle in that case. I actually have some spare PP that I could use to sew the two together. Thanks for the advice! |
| Author: | Old Timer [ Mon Mar 10, 2014 5:32 pm ] |
I also made a set after seeing Bassfriend's post. I did pretty much as Svendawg described but I wasn't sure how long to make them so I sewed the webbing around the shock cord rather tightly and then did an overhand knot on each end of the shock cord so that I can tighten or loosen it as needed. Now finished I find that having the ability to adjust the length to be useful. I don't Know if the others had trouble with installation but I did. When I removed the screws in the handle I found that I could slide the webbing under the back screw and replace the screw OK but when I tried to slide it under the screw with the steering arm I couldn't so I had to remove the handle. When I did that the steering rod flew into the bottom of the boat. It was no big deal to get it back in place but it required 2 people since the person who finds it and pushes it up into the hole can't reach it when it comes through the handle. I find this to be an excellent innovation that keeps the paddle and the staking pole out of the way. I have the same setup on my Tarpon 120 and am used to it. Thanks to Bassfriend for thinking of it and sharing. |
| Author: | Cdcraw550 [ Tue Mar 11, 2014 6:03 am ] |
I am going to do the shock cords, but I am going to try an alternate method vs. removing the grab bars and placing them there. I may just add several of the "knobs" and loop the cord in that manner. I can then use the cords for other purposes and have several on hand at any given time. |
