| PA tool kit http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=51427 |
| Author: | jslager [ Wed May 28, 2014 10:25 am ] |
| Post subject: | PA tool kit |
What tools do folks carry to cover most situations where you would need to fix something on your PA? |
| Author: | Elgeebee [ Wed May 28, 2014 7:13 pm ] |
| Post subject: | Re: PA tool kit |
A small wrench for the cable tension nuts, and an allen wrench for the main rod/pulley rod keeper screws on the Mirage Drive. My regular fish pliers come in handy too, especially for removing the round wire pieces that hold the fins on. Several times I've had to remove a fin to bend a rod back, while on the water... |
| Author: | markbxr400 [ Fri Jun 20, 2014 10:47 am ] |
Tools: Pliers, adjustable wrench, phillips head and flathead screwdrivers, allen wrench to fit drive set screws, allen wrench to fit rudder pulley. Spare parts include: For mirage drive - spare fin/mast (when I upgraded my Outback and Revo to ST Turbos, I had 4 spare standard fins/masts), sprocket, outhaul block, clevis pin and lock ring For rudder - Rudder pin Rudder drum screw Sister screw set for rudder |
| Author: | islandspeed2001 [ Fri Jun 20, 2014 12:33 pm ] |
markbxr400 wrote: Tools: Pliers, adjustable wrench, phillips head and flathead screwdrivers, allen wrench to fit drive set screws, allen wrench to fit rudder pulley. Spare parts include: For mirage drive - spare fin/mast (when I upgraded my Outback and Revo to ST Turbos, I had 4 spare standard fins/masts), sprocket, outhaul block, clevis pin and lock ring For rudder - Rudder pin Rudder drum screw Sister screw set for rudder Any room left for fishing gear |
