| Request for Closeup Hobie Cradle Pictures http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=54438 |
| Author: | vegasvec [ Tue Apr 14, 2015 3:19 pm ] |
| Post subject: | Request for Closeup Hobie Cradle Pictures |
Hello, Can someone post close up pictures of the Hobie cradles? I am specifically trying to figure out how they will be mounted to a retrofitted trailer. I am having a custom trailer built, so I want to make sure I see how others have mounted them. I have my cradles on order currently, but hoping to get the manufacturing of the trailer going in the mean time. Thanks in advance! |
| Author: | mmiller [ Tue Apr 14, 2015 4:43 pm ] |
| Post subject: | Re: Request for Closeup Hobie Cradle Pictures |
![]() https://static.hobiecat.com/item_attachments/72020401z52.pdf Outer pads cover the bolt holes. The cradles are flat on the bottoms in those areas. Easily mounts to a flat surface. |
| Author: | vegasvec [ Sat Apr 18, 2015 5:35 am ] |
Thanks Matt. You answered my question. I was wondering how they were bolted on to the trailer. I assume the pads are installed after the bolt is installed? Also, what is the optimal locations of the cradles? |
| Author: | mmiller [ Sun Apr 19, 2015 11:19 am ] |
Yes bolts first then install the pads. On carpeted versions you cut a slit to pass the bolt through. 67" for best fit. These are formed to specific points on the hull. |
