| HD Cart does not fit 2015 PA12 http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=54575 |
| Author: | eclipse504 [ Mon Apr 27, 2015 10:42 pm ] |
| Post subject: | HD Cart does not fit 2015 PA12 |
I purchased a new HD cart and the rubber stops dont seem to sit right on the hull or scuppers. Was there a design change that requires a different model cart? |
| Author: | Snookmeister [ Tue Apr 28, 2015 4:07 am ] |
| Post subject: | Re: HD Cart does not fit 2015 PA12 |
Do the metal posts not stick all the way through? I had to adjust mine and move the stoppers down a ways to get it to stick through enough to use the cart keeper pin. Mine are down like all the way to the bottom. |
| Author: | eclipse504 [ Tue Apr 28, 2015 7:45 am ] |
The metal posts go through the scuppers and show through the top. Its the rubber stoppers that dont seem to fit the bottom of the hull. When both stoppers are on, one side seems to fit the mold of the hole and the other seems to stop at the bottom of the hull before reaching the scupper hole. I tried turning it around in every combination but it doesnt seem to sit well. Does anyone else have this or can show a pic of how its suppose to sit? |
| Author: | Thinwater skinner [ Tue Apr 28, 2015 8:29 am ] |
I believe there are two sets of holes/scuppers.. Have you tried both set of holes? Mind won't fit in one, but will in the other... Good luck |
| Author: | mmiller [ Tue Apr 28, 2015 10:57 am ] |
Not a problem. The stoppers or "Cart Clamps" do not have a net fit to most scuppers, but the contact points are hitting on thicker hull material which is desired over the crossbar denting the radius bottom. |
| Author: | SWFLGamecock [ Tue Apr 28, 2015 6:56 pm ] |
Great idea Cory! |
| Author: | Yak9107 [ Wed Apr 29, 2015 6:51 am ] |
I went with the tennis ball method... |
