| Rod holder tubes http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=55781 |
| Author: | svendawg [ Mon Aug 24, 2015 8:46 am ] |
| Post subject: | Rod holder tubes |
Are the rod holder tubes supposed to be water tight. I didn't have a leak on my last PA but on my new 2015 PA-12, I noticed water in the hull after an outing. When I wash the PA water leaks out of the end of the rod holder tubes into the hull. should these tube be water tight. By the way, I love the upgrades Hobie made on the 2015 PA-12. It now tracks straight w/o a lot of rudder corrections and the H-rail is awesome |
| Author: | SRAces [ Mon Aug 24, 2015 9:31 am ] |
| Post subject: | Re: Rod holder tubes |
I always find a little water in my PA14s after washing. The bottom rod holders capture the water that runs into them from the floor. I have totally removed those rod holders on my 2012 PA14 to get to side board screws at the front. The tubes are pinched off at the ends. I can't remember if they are totally sealed by the plastic coming together as a tab. If you're seeing water coming out that pinched area while putting water down the tubes with the front hatch open, then I would take the tubes out and seal the ends. There is a gasket behind the front rod tube plate as well, but it sounds like you are seeing the water come out the pinched ends. |
| Author: | svendawg [ Sun Aug 30, 2015 9:49 am ] |
Pulled the rod tubes out this weekend and filled with water. All four tubes leaked badly. Sealed with silicone sealant and tested. Now dry when filled. Just a heads up for those PA owners that are seeing water in their hull after an outing. |
| Author: | SRAces [ Sun Aug 30, 2015 10:57 am ] |
Thanks for confirming what the issue was. I'll bet mine have a similar leak. I might yank mine out and do the same. |
