| 17t hole under deck pads?? http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=56977 |
| Author: | vegasvec [ Sun Feb 28, 2016 9:33 pm ] |
| Post subject: | 17t hole under deck pads?? |
I have uploaded a picture to this post so hopefully it goes through. But there is an indentation below the rear left deck pad. Any idea what this is? I purchased the kayak in May '15 and have used it less than 10 times. Is there a hole in the kayak in this area?? ![]() Sent from my iPhone using Tapatalk |
| Author: | Dr.SteelheadCatcher [ Sun Feb 28, 2016 10:37 pm ] |
| Post subject: | Re: 17t hole under deck pads?? |
| Author: | vegasvec [ Mon Feb 29, 2016 8:06 am ] |
Yes, it feels like there is some foam there which wraps around some support I think? Can anyone from Hobie confirm this isn't an issue? Thanks. Sent from my iPhone using Tapatalk |
| Author: | Jbernier [ Mon Feb 29, 2016 10:04 am ] |
There are scupper tubes that attach the deck to the hull bottom all along the deck to support the weight. They're on all PA17t's |
| Author: | Mamacocha [ Mon Feb 29, 2016 8:07 pm ] |
My PA14 has holes under the foot pads too. They were covered with black tape when I pulled the pads off. ______________________ The Mama Cocha Hobie PA 14 / Illinois USA Sent from my iPhone |
| Author: | Ranger [ Fri Mar 11, 2016 7:54 am ] |
You can pull the pads off, determine what the hole is, contact Hobie,and then stick it back on. The only reason I say this is I put in after market flooring (Sea Deck)which require removing the factory pads. I repurposed those pads for the bow hatch so my dogs can run around the whole deck and not slip. As soon as I figure out how to post pictures I will. Hope this helps! Also, do you Fish Lake Mead?? |
| Author: | vegasvec [ Sun Mar 13, 2016 9:39 pm ] |
Hesitant to pull up the factory pads as I'm concerned they will either bubble or not stick again. And Yes I fish Lake Mead. Sent from my iPhone using Tapatalk |
| Author: | Ranger [ Mon Mar 14, 2016 8:48 am ] |
I've removed the pads and reapplied them and they stick just fine. also I'm from vegas as well and would like to fish lake mead ya sometime. |
