| Mounting a Helix & 360 http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=60157 |
| Author: | Tundah [ Wed Mar 22, 2017 5:20 pm ] |
| Post subject: | Mounting a Helix & 360 |
What are you folks using to mount your bigger screens? I just ordered a Helix 9 and need some ideas. Also got the HB 360 transducer (trolling motor) and I need to figure out a way to mount it off the h-rail so it can stow parallel to the h-rail and obviously deploy straight down off the side. Appreciate suggestions |
| Author: | scotty918 [ Fri Mar 24, 2017 6:39 am ] |
| Post subject: | Re: Mounting a Helix & 360 |
I'm at work, but as soon as I get home, I'll post a picture of my rig. I bought two Ram mounts so I could have options. I have the Helix 10, so I bought the large Ram components (D-size). Option 1: I drilled into the plastic mounting plate on the front starboard side. Then I mounted this... http://www.rammount.com/part/RAM-D-202-25-C-202U However, I found I like the head unit closer to my face, so I bought a D-size ball-clamp component and tightened it around my h-bar close to the seat. I LOVE this setup because it brought the screen closer to my face. I used some bicycle tube from walmart to protect that area of the h-bar from the ram clamp. The rubber on the tube also provides friction and prevents ANY sliding on the h-rail. http://www.rammount.com/part/RAM-D-271U-12 |
| Author: | HStrech [ Mon Mar 27, 2017 11:23 am ] |
For mounting your head unit, a 1.5" H-Rail Ram ball will do the job. If you're only interested in the 2.25" RAM ball, then I'd mount to one of the mounting boards on your PA. |
| Author: | Tundah [ Thu Mar 30, 2017 4:35 am ] |
Thanks I went with the 2.25, looks sturdy Sent from my iPhone using Tapatalk |
