Hello -
I had a trailer made with PVC bunks for a PA 14. I haven't bought the kayak yet, but I thought if I had the trailer, the dealer could set the new kayak on the trailer and I'd be good to go.
The PVC pipe is held in place by galvanized metal that has been welded to the frame of the trailer and screwed to the PVC. I measured the distance on center between the pipes, and it is exactly 10", which from everything I've read, seems too narrow. The only way to move the PVC will be to have the welded pieces cut off and either re-weld them or attach a strut channel to the trailer so the PVC can be adjusted once I have the PA 14.
Is 10" too narrow, and which solution would be recommended if the pipe needs to be farther apart?
Thanks!
