| Heel Straps for your Pedals http://www.hobie.com/au/en/forums/viewtopic.php?f=82&t=39389 |
| Author: | Mary Skater [ Mon Oct 24, 2011 2:22 am ] |
| Post subject: | Re: Heel Straps for your Pedals |
I've only pedalled a Hobie once, for a few hours in a hired boat, but I found it quite a strain holding my legs up in that horizontal position. Maybe more careful adjustment of seat and pedal positions would have helped, but I came off that trip knowing that, if/when I buy my own Hobie, heel straps will be the first mod on my list. I wonder if people who use recumbent bicycles have similar issues. Thanks for the detailed how-to, Roadrunner. Mary |
| Author: | cosybike [ Thu Nov 17, 2011 12:38 pm ] |
Perfect! - Under construction! Thanks RR. |
| Author: | dregsfan [ Fri Nov 18, 2011 5:26 am ] |
I've had my Adventure for over a year. I've never felt the need for heel straps. I think it all depends on the soles of the footwear used. |
| Author: | rrdstarr [ Mon Sep 03, 2012 3:22 am ] |
I think this is a great idea! I need to find a source of sheet neoprene or strap in Canada! My size 13's With Keen sandals on do not fit the toe straps and have been off since day one! |
| Author: | Roadrunner [ Mon Sep 03, 2012 7:02 am ] |
rrdstarr wrote: I need to find a source of sheet neoprene or strap in Canada! Try a gasket supply shop. |
| Author: | Leeder [ Wed May 20, 2015 11:43 am ] |
Sorry to bump up an old thread, but just bought myself a n Outback and hate the foot straps, would love to try this heel strap mod, some of the photos are missing from the original thread, just wondered if you still had them Roadrunner and if so if you would mind sharing them again? Thanks in advance. |
| Author: | rrdstarr [ Wed May 20, 2015 2:47 pm ] |
Nothing wrong with resurrecting an old thread! I still need to make mine. A back injury two years ago stopped me from pedalling. Got the all clear last week! Time to get back out on the water! |
| Author: | Dr.SteelheadCatcher [ Wed May 20, 2015 3:58 pm ] |
I "stole shamelessly" roadrunners great idea a couple of years ago and made heel straps out of some extra 1" wide, NRS tie down strapping I had left over. I used an old soldering iron to melt the nylon strapping, to make the rectangular slots to fit the Hobie pedal tabs. I also "doubled over" the strapping as its thinner than the neoprene as you can see in the attached photo.......I love the heel straps for all the reasons mentioned above. I wear size 12 water sandals, so I simply connected the strap to the inside pedal tab, laid my shoe in the strap and formed it around the heel, to where the ball of my sandal was centered on the pedal, marked the location for the outside slot and melted the rectangular hole.....folded over the strap and melted the second outside hole......duplicated the last strap from the first one used as a model. It's easy to make and well worth the hour of labor.
| Author: | motorcycle_jack [ Fri May 22, 2015 7:02 pm ] |
Wow, thanks for the mod. It was something I have been thinking about as I just bought an Oasis. And as I have a form of muscular dystrophy that affects my leg muscles and can't hold my legs up on the pedals. I have ridden my recumbent but use clip-in pedals with a corresponding cleat in the bottom of a bicycle shoe but didn't really want to do that on the water. Your solution is perfect. |
| Author: | RockyRaab [ Sat May 23, 2015 9:02 am ] |
I'm pretty happy with the way my Crocs jam into the factory straps, and their heel strap holds my feet up nicely. But if I do make this mod, I'll use 1ΒΌ" military web belt material. It's stiff enough that it won't twist, tangle, or flop around. |
| Author: | ps.gonefishn [ Tue Apr 11, 2017 2:03 pm ] |
Thanks for response and great detail. This is what I had in mind, you have just solidified it for me. |
| Author: | wallupop [ Tue Apr 25, 2017 7:54 pm ] |
This topic was exactly what I was looking for Thank You |
