| H-20 Mast Rotator http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=1131 |
| Author: | Shane [ Tue Sep 07, 2004 11:48 am ] |
| Post subject: | H-20 Mast Rotator |
I have seen Mast rotators on H-20 at some of the regatta's I have been to but none of the stores seem to know much about them and definatly don't have one to buy. What does it take to make one how is it attached and how or what does it do. Also having a problem with my rudders cams not rotating back up when tripped. Any solutions. What is the easiest way to rotate them back up without pulling out the tension spring. shane |
| Author: | mmiller [ Tue Sep 07, 2004 2:21 pm ] |
| Post subject: | Questions |
The cam question is coverd in detail in the FAQ section... http://www.hobiecat.com/community/viewtopic.php?t=467 All of the 20s have a standard rotation limiter. That is a rotator arm at the mast base with a line system running to each hull. The rotator (positive rotation control)? There is a standard system we have on the 20s now. There is a comlete assembly manual (pdf) in the support area (Support link at the top of this page). Here is a direct link: http://www.hobiecat.com/support/pdfs/H20Manual.pdf This explains both rotation systems. |
| Author: | sunjammers [ Wed Sep 08, 2004 8:10 am ] |
| Post subject: | |
Any Hobie dealer will be able to get you the parts you need if they do not have them in stock! Thanks, Brad Stephens www.sunjammers.com Hobie Division 15 Chairman Authorized Hobie/Vanguard/Hunter Dealer [email protected] 850-235-2281 Panama City Beach, FL |
