| rudders http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=13039 |
| Author: | abbman [ Sat Jul 11, 2009 8:07 am ] |
| Post subject: | rudders |
Can I use rudders from a Hobie 17 on a 16? I think the answer is yes, but I don't know. |
| Author: | mmiller [ Sat Jul 11, 2009 9:24 am ] |
| Post subject: | Re: rudders |
The entire rudder system? The biggest issue will be the lower casting. There is a difference in the gudgeons and their spacing. I doubt there is room on the transom for the required spacing. |
| Author: | abbman [ Sat Jul 11, 2009 9:38 am ] |
No, just the rudders. I would be using the 16 assembly and castings. |
| Author: | MBounds [ Sat Jul 11, 2009 9:51 am ] |
You can use them, but the bolt holes are in different locations. I used to have a spare rudder that was drilled for both - my recollection is that the hole for the upper casting is roughly in the same location for both (or at least you can make it work there). |
| Author: | abbman [ Sat Jul 11, 2009 1:53 pm ] |
Ok. Thanks for the replies. I'm looking to buy a pair of EPO's that were used on a 17. I assume I can fill and drill as need be as long as the rudders are the same. |
| Author: | mmiller [ Sat Jul 11, 2009 2:54 pm ] |
Yes... that would work. You will love the EPOs! |
| Author: | abbman [ Sat Jul 11, 2009 5:20 pm ] |
Thanks for your quick replies. I'm really digging this racing thing and I'm now looking for more of the go-fast stuff. |
