| Adjusting a harness http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=27354 |
| Author: | ET Hobie guy [ Mon Jul 05, 2010 7:31 pm ] |
| Post subject: | Adjusting a harness |
My wife bought a new Hobie skippers harness for me on Fathers Day. I used it for the first time today and was wondering if there is a specific way it should be adjusted. I know it should seem straight forward, but anyone who backpacks knows in order to get the proper fit when you throw the pack on your back it is imperative you adust the various straps in a specific sequence and by the proper amount to get the most comfort from your pack which almost any novice would not know. I was just wondering if there is a similar sequence with the harness. Walter |
| Author: | ET Hobie guy [ Tue Jul 06, 2010 7:38 pm ] |
| Post subject: | Re: Adjusting a harness |
Hmm, I must be making it into something it isn't. I suppose its no more difficult than just yanking away on straps until it feels right. |
| Author: | hobie18rich [ Tue Jul 06, 2010 9:20 pm ] |
its just what ever feels good to you once you get out on the wire no special sequence or trick its just comfort for you. |
| Author: | mmiller [ Wed Jul 07, 2010 10:57 am ] |
I find it best to tighten the leg starps a bit first to hold it down low... then tension the heck out of the bar / waist straps to hold it there. Uncomfortable if it slips upwards. |
| Author: | sunvista [ Wed Jul 07, 2010 1:13 pm ] |
Trial and error. And after you get it just the way you want....don't let anyone else use it. |
| Author: | ET Hobie guy [ Wed Jul 07, 2010 5:38 pm ] |
Thanks, Also, I was little concerned my wife bought one too large. It is a large and my waist size is 33 - 34. I guess I shouldn't be too concerned. It leaves room for an expanding girth!! |
| Author: | mmiller [ Thu Jul 08, 2010 9:38 am ] |
Well... it should pull tight at the hips I think. Otherwise you just slip down and rest on the leg straps... or worse! |
