| pressurizing a 17 http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=3403 |
| Author: | mhuiz05 [ Wed Apr 19, 2006 9:31 am ] |
| Post subject: | pressurizing a 17 |
i have a 1987 hobie 17. it leaks a little bit and i want to seal the holes with fiberglass. Any good ideas on products to use and the whole process of it all. Thanks |
| Author: | mmiller [ Wed Apr 19, 2006 9:49 am ] |
| Post subject: | Leak check |
There is a FAQ on leak checks: http://www.hobiecat.com/community/viewtopic.php?t=169 The 17 has vents in the forward saddles and this should not be blocked. If they leak in the wing tubes, you have to cut access ports in the deck and patch from the outside of the tube - inside the hull. |
| Author: | mhuiz05 [ Mon Apr 24, 2006 7:18 am ] |
| Post subject: | |
Any good ideas of what to put in the wing shockets? How would i do it and what material should i use. I know glassing works but no idea how to do it. Any ideas? |
| Author: | MBounds [ Mon Apr 24, 2006 10:40 am ] |
| Post subject: | |
Go here to get the latest issue of the HCA HOTLINE magazine: http://www.hobiecat.com/hobieclass/ On page 27 there's a description of how to repair a wing tube leak. |
