http://www.hobie.com/au/en/forums/
Light wind
http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=36329
Page 1 of 1
Author:  hobie1canobe [ Wed Jun 22, 2011 6:06 am ]
Post subject:  Light wind
I am a fairly new sailor and I've been dealing with a lot of light wind lately, and am wondering if what I am doing is correct and if there is anything else I can do to help performance.
This is what I am currently doing on my 2008 Getaway:
(1) Mast rake - using the standard Getaway setup, I am raking the mast slightly forward so the shroud wires are only two holes from the top, and the forestay pulls deep into the adjuster at the bridle.
(2) Downhaul - I am only gently pulling the wrinkles out of the sail.
(3) Main sheet - sheeted snug but not tight to maintain sail curve
(4) Main clew - main block is attached through the furthest aft/leech clew hole
(5) Jib - jib sheet is dual tensioned to create a bit of curve (after the leeward jib sheet is set, the lazy jib sheet is slightly tensioned).
Are these things even helpful/correct to increase light wind performance?
Are there other suggestions to increase light wind performance?
Author:  Little Wing [ Wed Jun 22, 2011 10:36 am ]
Post subject:  Re: Light wind
The getaway is not a good light wind boat a bit heavy
Author:  hobie1canobe [ Wed Jun 22, 2011 7:04 pm ]
Yes. That's precisely why I need to know the best way to rig it for light wind. I'm still going to sail! But how can I maximize light wind performance?
http://www.phpbb.com/
