| What blocks to get for my H18 http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=4620 |
| Author: | splash [ Sun Aug 20, 2006 12:38 am ] |
| Post subject: | What blocks to get for my H18 |
Hi guys what setup should i do for my H18?? 6:1 or 7:1?? Rachet? on both top and bottom? only bottom? What is the objective of a rachetting block? make it easyer to hold the line when uncleated correct? Rachmatic , rachet? what would you get? Also what mainsheet would you recomend and why? 3/8" or 7/16" Theser are some recomended options by my dealer 1) 6:1 - 3/8" mainsheet lower: HAR 2141 - $175.85 US or HAR 2630 - $240.20 US upper: HAR 2604 - $114.30 US 2) 7:1 - 3/8" mainsheet lower: HAR 2141- $175.85 + HAR 2636 - $22.80 US installed on the 2141 becket. or HAR 2632 - $257.30 US upper: HAR 2605 - $120.25 US 3) 6:1 - 7/16" mainsheet lower: HAR 2686 - $310.20 US upper: HAR 2664 - $166.90 US 4) 7:1 - 7/16" mainsheet lower: HAR 2687 - $349.65 US upper: HAR 2665 - $176.85 US Thanks! |
| Author: | Hobie Nick [ Mon Aug 21, 2006 5:34 am ] |
| Post subject: | |
My H18 came with a good setup. I'm not sure of the part numbers, but they are all Harken. I have a 7:1 setup and the lower block only has the ratchet. This ratio is a good balance between the amount force needed to sheet in and the amount of line. Get the ratcheting block. On a long gusty day you will be very glad you did. You are correct in saying that is helps hold the sail without cleating. Well worth the money. |
| Author: | ncmbm [ Mon Aug 21, 2006 6:17 am ] |
| Post subject: | |
I run a 8:1 system I removed from my Fox before selling it. It has the ratchet on the lower which I would recommend. Don't see a need for racheting upper blocks. |
