| Broken Pylon repair possible? http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=4842 |
| Author: | Sailin817 [ Sat Sep 09, 2006 7:41 am ] |
| Post subject: | Broken Pylon repair possible? |
Hey everyone, I am looking at buying a new set of hulls for my H-16 however, the hulls that I have found (very solid) have a broken pylon. Is this repairable? If it is where might I find information on repairing such a problem. Thank you in advance to everyone, Andre |
| Author: | The Dog [ Sat Sep 09, 2006 6:07 pm ] |
| Post subject: | |
Repairable? Maybe. But probably not without a lot of work and/or money. If you want to install a pylon from the old hull, it involves a lot of glass work. The pylons are glassed into hulls at the deck and the bottom of the hull. You will have to cut a hole into the side of the good hull to glass a new pylon in. If you want to repair the existing pylon, you'll need a welder with a deft touch. Welding thin aluminum is already tricky. You have the added problem of wanting to keep the heat away from the aluminum/glass joint. Brian C |
