| Mesh Tramp http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=49104 |
| Author: | sxrracer [ Thu Aug 29, 2013 2:53 pm ] |
| Post subject: | Mesh Tramp |
So, I go out to the sailing club a few weeks ago and I notice my new Hobie Mesh tramp has what looks like mildew building up...... What do you all use to clean it? I lightly scrubbed it with original Dawn (Blue)....... Helped some........... Tips? |
| Author: | sxrracer [ Mon Sep 02, 2013 7:09 am ] |
| Post subject: | Re: Mesh Tramp |
Nobody? |
| Author: | BrianCT [ Mon Sep 02, 2013 7:45 am ] |
Barkeeper's Friend worked very well on my solid vinyl tramp and hulls. The active ingredient is oxalic acid (see:OxiClean infomercials). It is supposedly environmentally friendly but nevertheless you will want to wear gloves. |
| Author: | PurdueZach [ Mon Sep 02, 2013 9:07 am ] |
BrianCT wrote: Barkeeper's Friend worked very well on my solid vinyl tramp and hulls. The active ingredient is oxalic acid (see:OxiClean infomercials). It is supposedly environmentally friendly but nevertheless you will want to wear gloves. I can confirm this. BKF works extremely well on hulls and I have had success with vinyl tramps. I've never tried it on a mesh tramp though. |
| Author: | MVD [ Tue Sep 03, 2013 2:44 pm ] |
I just use car was soap and a soft bristle brush on my mesh trampolines. It does a good job and probably not as harsh as oxalic acid. I've had good results with oxalic acid on white hulls. |
| Author: | gary eudy [ Fri Sep 06, 2013 8:39 am ] |
try spray 9 from west marine |
| Author: | mmiller [ Fri Sep 06, 2013 8:46 am ] |
No help here... We don't get mildew. |
| Author: | sxrracer [ Fri Sep 06, 2013 9:16 am ] |
I had been storing it with my old tramp on top and a Tarp over all of it. Where my boat is parked in the boat yard it is near a bunch of Pine Trees, I was worried about limbs falling and going through the tramp.... Thinking this was the cause, have since stopped placing the old tramp over the new now hoping that will help......... |
| Author: | ftlauderdale16 [ Sun Sep 15, 2013 6:48 am ] |
Bleach is a sure way to kill mold... You can use a light solution - 1/4 cup bleach to 3/4 water. If its not quite doing the trick, make it a 50/50 mix. Just be sure to thoroughly rinse afterward. Have a Hobie Day! Sent from Tapatalk |
| Author: | gary eudy [ Wed Sep 18, 2013 6:34 am ] |
should have said use a 3000 psi pressure washer which is what I use use the fan setting and not to close Former Hobie Admiral Gary |
| Author: | sxrracer [ Wed Sep 18, 2013 8:46 am ] |
I actually tried that, I bought a new Pressure washer, Everytime I borrow my dads, he always comes up with a project and needs it back, so, I picked up one a few weeks ago and went out to do some cleaning on the boat. Did not really help much, but I was afraid to get to aggressive. |
| Author: | sxrracer [ Sun Oct 06, 2013 4:44 pm ] |
Clorox at around a 10-15:1 mix got most of it. |
