| Vertical post roller for trailer, cannot find anywhere! http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=51221 |
| Author: | ebs675 [ Fri May 09, 2014 6:08 am ] |
| Post subject: | Vertical post roller for trailer, cannot find anywhere! |
All, I have been looking everywhere to find a vertical post roller guide, that can be mounted to my trailer on the inside of the hulls. I have seen these on other trailers so I know they exist, and they are so simple, but I have scoured the web and cannot find them anywhere. I hope I am adequately describing what I am looking for. Basically, it is just a straight vertical post that mounts to the frame with u bolts, and then it has a horizontal roller at the top of the post that would contact the inside of the hull. Any help finding this would be much appreciated. I have looked everywhere. Thanks !!! |
| Author: | danneskjold [ Fri May 09, 2014 6:54 am ] |
| Post subject: | Re: Vertical post roller for trailer, cannot find anywhere! |
I've found catamaran trailer parts at the trailer parts depot http://www.trailerpartsdepot.com/items.asp?Cc=APONT-CR They have roller brackets with up-right guides. |
| Author: | PurdueZach [ Fri May 09, 2014 7:14 am ] |
If I remember correctly, those things are really expensive! If you or someone you know is a decent at welding, have them add a guide like this. Just metal stock welded at an angle to the existing bracket. Then just put a pool noodle on it.
