| X-beams & mast , need some white paint http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=57169 |
| Author: | Bille [ Mon Mar 21, 2016 7:12 pm ] |
| Post subject: | X-beams & mast , need some white paint |
Las Vegas is gonna be over 112 to 115-deg F this summer ; and i'm getting tired of burning my hands on the black anodized parts. Their going to get White paint (.) What kind of paint should i use ? How should i prep the parts ? Thanks : Bille |
| Author: | cpnsoo [ Mon Mar 21, 2016 9:53 pm ] |
| Post subject: | Re: X-beams & mast , need some white paint |
Paint gets scratched off easily. I used black auto trim paint on an anodized frame and it looks like hell, especially on the front member where the jib blocks make contact. Better off with a carpet kit on the side rails as these are the ones you're probably touching the most. |
| Author: | OlderBowman [ Wed Mar 23, 2016 9:27 am ] |
it's true that paint will scratch, but it's better than burning hot bars. epoxy paint is what I'd try, a spray job will give an even coat. or see if electrostatic powder coating will work on the aluminum (costly and needs a contractor for the job). there are some forms of hull paint that may work as well, again costly compared to epoxy paint. I painted my comp tip white many years ago, mostly to keep off the UV damage. maybe I'll go for a florescent color next time |
| Author: | ToddE [ Wed Mar 23, 2016 3:16 pm ] |
I have used appliance paint with reasonable results. It can be scratched, but it lasts pretty well for little time invested. |
| Author: | Bille [ Wed Mar 23, 2016 9:49 pm ] |
I'm going with OlderBowman's suggestion , and look for a good epoxy paint ; i'll call the manufacturer to enquirer how to prep there paint for aluminum. Epoxy paint is strong ; they even use it in pools !! Bille |
