| Dolphin striker needed to hc14 http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=57997 |
| Author: | pah60 [ Thu Jun 16, 2016 8:59 am ] |
| Post subject: | Dolphin striker needed to hc14 |
I will ask if I need a dolphin striker on my HC14 when i sailing with trapets? and where can I get it? I had have the boat for four weeks. |
| Author: | MBounds [ Thu Jun 16, 2016 12:19 pm ] |
| Post subject: | Re: Dolphin striker needed to hc14 |
Yes, you must have a dolphin striker when sailing a 14 with a trapeze. Where are you located? (English is obviously not your first language.) That will determine where you can get a dolphin striker. |
| Author: | pah60 [ Thu Jun 16, 2016 11:45 pm ] |
yes I am from sweden and I have speak to hobie shop in Stockholm but they have only strikers to hc 16. can I built a striker my self? or buy some els? vgh pah60 |
| Author: | MBounds [ Fri Jun 17, 2016 5:17 am ] |
A Hobie 16 dolphin striker is too long for a 14, although you could probably use the post (center vertical bar). A Hobie 17 dolphin striker can be adapted to a 14 - it is the correct length and you just need to bend the ends of the rod a bit and cut off part of the post. However, to install these on an old 14, you will also need to replace the mast step, since the post threads into it and the original 14 step does not have a threaded hole for it. What you need is the retro-fit kit: There's one on eBay right now. |
| Author: | pah60 [ Fri Jun 17, 2016 7:10 am ] |
Thanks for the tip and I have contact the seller for the retro-kit. |
