| Hobie 16 Main Sail Help http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=5905 |
| Author: | Benjaminlbarker [ Fri Jan 19, 2007 11:10 am ] |
| Post subject: | Hobie 16 Main Sail Help |
My newly acquired H16 has an older set of sails. So old infact that it still has reefing gromets. I am having some problems with how it all fits together when properly rigged. I think that the tack has been repaired badly causing the tack not to fit right into the gooseneck fitting. I need good, clear close up picture of the tack of an H16 main to compare what mine is supposed to look like. I have seen a good picture of it rigged I just want to see the sail by itself now. Any body got a good cheap used set of sails in south florida? Thanks for your help in advance! |
| Author: | sunjammers [ Thu Feb 01, 2007 7:41 pm ] |
| Post subject: | |
maybe if you can get a picutre of your sail we can try and figure it out for you, not sure when i can get a picture of a sail for you! |
