| Very small surface crack in comptip http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=61001 |
| Author: | leecea [ Mon Jul 10, 2017 7:01 am ] |
| Post subject: | Very small surface crack in comptip |
I noticed a 1/2" crack just above where the comptip joins the bottom mast section. Looks like just a shallow surface crack. I was going to put some cheap "marine" epoxy in it - not sure that will do much but I assume it does no harm and the crack is not a big deal. Let me know if that's not the best thing to do. |
| Author: | srm [ Mon Jul 10, 2017 8:11 am ] |
| Post subject: | Re: Very small surface crack in comptip |
leecea wrote: I noticed a 1/2" crack just above where the comptip joins the bottom mast section.... the crack is not a big deal. Sounds like wishful thinking. The part of the comptip right where it inserts into the aluminum section sees the highest load. I would make sure it's not a structural crack because if it is, just slapping a little epoxy on it isn't going to do anything. I'd rig the boat up, crank the main sheet in real hard, and put the boat on it's side and take a look. See if the crack spreads open or looks worse. If the crack is deeper than just a few thousandths or you can see broken glass fibers, I would not consider it to be non-structural. sm |
| Author: | leecea [ Mon Jul 10, 2017 11:12 am ] |
Yes, some wishful thinking I suppose. I'd read that there is gelcoat there and I thought (hoped) that was all that was cracked. I doubt I've sailed it much more than 20 hours since new but it does get trailered with the mast assembled. I will take a closer look. It's a Wave BTW. |
| Author: | mmiller [ Mon Jul 10, 2017 1:54 pm ] |
Chips and small cracks happen at the joint due to movement while sailing. Very little chance that it is more than cosmetic. |
| Author: | RobDek [ Wed Jul 12, 2017 3:38 pm ] |
Grind out the bad, fill it with thickened epoxy and then paint. Repeat as needed. Water will penetrate into the comptip sooner or later, when it freezes...pop. |
