| matt miller...comptip epoxy sequence help http://www.hobie.com/au/en/forums/viewtopic.php?f=9&t=64570 |
| Author: | deejay [ Thu Apr 18, 2019 5:30 pm ] |
| Post subject: | matt miller...comptip epoxy sequence help |
Matt, Am replacing a comptip on my H18. Should I epoxy the comptip in place and let dry BEFORE inserting rivets for the tang ...OR should I rivet the tang in place immediately after epoxying the tip in place?????OR, Does it matter which way to go???? Any help is appreciated ..... deejay |
| Author: | mmiller [ Fri Apr 19, 2019 8:42 am ] |
| Post subject: | Re: matt miller...comptip epoxy sequence help |
Let the epoxy harden / cure first. You need to keep the tip in alignment while it cures... then pop the rivets. |
| Author: | deejay [ Fri Apr 19, 2019 12:26 pm ] |
Matt, thanks for the info....Deejay |
| Author: | mmiller [ Thu May 16, 2019 7:54 am ] |
I would give it 12 hours for a complete cure. When I use Bondo, I can usually rivet after about an hour. I also use GFLEX and that takes a bit longer. It depends on heat and how much catalyst used. In Bondo, you can use too much catalyst and damage the integrity of the material as well. |
