It is currently Tue Jun 02, 2020 3:15 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Yakattack Tracks
PostPosted: Fri Feb 07, 2014 10:06 am
Mounting in that area can be a bit tricky because of the AI dagger-board slot. I have mounted a RAM ball mount there on each of my AI's. Best is to have the hull raised so the center of the middle hatch is about shoulder level (while sitting or kneeling) to get the most comfortable position for you, as your body will be up against the hatch opening for your arm to go beyond the dagger-board slot and then up around the mesh pocket well. Can be done, but is not very comfortable for very long if you are bending over the hull to start with.
Good luck, it should turn out great!
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
PostPosted: Fri Feb 07, 2014 11:41 am
Thank you very much. It is the first time I am trying to open a hole on the hull. I hope not to destroy the yak.
PostPosted: Fri Feb 07, 2014 2:18 pm
After the first hole or two, it gets (almost too) easy, drilling and cutting on your new boat. Go for it! You will feel much better once it's done. :)
PostPosted: Sat Feb 08, 2014 12:34 am
I hope so. hehe
PostPosted: Sat Feb 08, 2014 12:41 am
The first twenty holes are the hardest! :mrgreen: :mrgreen:
PostPosted: Sat Feb 08, 2014 12:55 am
hahaha then I will try to to open the first 20 holes on a concrete wall.
