That's a good question. Hobie's original idea as I understand it, was to have a fin that could change its twist rate for different speeds, depending on the users capabilities. By tightening up the brass screw it makes the fin twist less and supposedly work better at faster boat speeds.
Unfortunately (in my opinion) it didn't seem to work out that way in practice. What ends up happening when the brass screw is tightened is the fins become more like boards and just bat water back and forth (relatively speaking). The more twist they get, the more forward thrust you get. This is achieved by loosening the brass screw to the setting I recommended above. What you're looking for here is to create about 1/4" space along the mast for the fin to slide up and down. This allows it to twist or warp (much like an airplane propeller) to its best advantage.
What difference does it make to you? When set tight, the Drive is harder to push at any given speed. Top speed is slightly reduced, at least for me. When you loosen them you can feel the difference -- same speed, less effort = less fatigue and greater range.
So why still have it? The cost to change production is not worth it. The fins still need an attachment mechanism and this works fine. Additionally, the original Turbo masts were a little longer so the clew adjustment allows the fins to be optimized for both lengths. Finally users who want to experiment with different clew settings can tune the fins individually to suit.
The factory has recently started outfitting some of the Drives with Turbofins for the Pro Angler. They're bringing them too close in IMO, just like your set pictured above. The first thing you should do is readjust them and give your legs a break!
The factory has an absolutely brilliant engineering staff, and I'm normally reluctant to recommend anything different than Hobie would. But in this case, I've spend hours trying different individual combinations of settings on these clew adjustments in a effort to extract the fastest sprint and cruise speeds from the Drive. Others here have found similar results. So give it a try and see what you think!
