It is currently Sat Jun 24, 2017 12:28 pm
 Post subject: Ok I did the leak test
PostPosted: Sun Feb 05, 2006 1:34 pm
I have air coming out of my hatchs, rudder lift handle, sail support
hole. and bungie hold downs. Where to go from here?
I not only tested it with air, I hosed it down with water too.
The back hatch, which I rarely use, seems the best.
The middle hatch leaks water inside.
The sail support leaks water inside.
Some of the screws leak water inside.
The front hatch did not leak with the hose.
As stated in previous post, even on flat clam water I still get water
inside. I,m gussing this is from the rudder system.
I will try to post photos of the test when I figure out how to
post them.[/img]
 Post subject: Leaks?
PostPosted: Mon Feb 06, 2006 10:16 am
I will see if our engineers can comment on leak repair for you.
