It is currently Mon Nov 20, 2017 2:48 am
 Post subject: Polyethelene Glue !!
PostPosted: Sat Feb 18, 2006 1:53 pm
Hobie Team Member
Is the search for a poly glue over?
From 3M
Two-part epoxies have evolved over three dis-
Among the most recent advances in acrylic tech-
nology are 3M Scotch-Weld Structural Plastic Ad-
hesives DP-8005 and DP-8010. These readily bond
polypropylene, TPOs, and other difficult-to-bond
low surface energy plastics. They provide high
shear and peel strengths while reducing the
surface preparation time and cost of traditional adhesives.
at:
http://www.pressreleasefinder.com/prdoc ... rticle.pdf
Unfortunately it looks like the small quantity tubes from Granger etc require a $40 applicator.See:
http://tinyurl.com/b6yqj
But also checkout 3M(TM) Scotch-Grip(TM) Plastic Adhesive 4693,
It has immediate bond strength, long tack range and contact bond properties. It exhibits outstanding bond strength to metals and many plastics, including polypropylene, polyethylene and high-impact polystyrene. Good resistance to water and aging.
4693H is a thicker version available in tubes at:
https://rshughes.com/products/021200_30088.html
I've ordered a tube and will post results later.[/i]
PostPosted: Wed Feb 22, 2006 12:19 pm
Hobie Team Member
Sorry guys I had to cancel the order for the$14 tube.
Because I'm in Hawaii they wanted to stick me $70 for shipping hazard material via UPS 2nd day air.(no USPS)
Someone can probably get it for $8 freight UPS ground.
