It is currently Tue Feb 19, 2019 1:12 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 22, 2018 7:05 am
Roadrunner wrote:
Pollo de muerte wrote:
Digging this thread up in hopes that RR will re-attach the photos.
Done. The original post has been edited accordingly. 8)
Muchas gracias!
2014 Outback
2016 Outfitter
2017 Sport
PostPosted: Fri Jan 11, 2019 1:09 pm
Online
I wish the OP image links worked... :(
Thank you,
Roy Niswanger
PostPosted: Fri Jan 11, 2019 8:14 pm
Roadrunner edited his OP so that all images show up again. I can see all the images.
PostPosted: Wed Jan 23, 2019 11:06 am
I am having trouble keeping the toe strap secure on the pedal. The outer quick release (slide over the knub) keeps releasing while I'm peddling. I know it has to be me. I have tightened them and placed the strap on the last hole and no matter what I do, the strap disconnects.
After looking at your rear strapping, maybe this is something I should try to manufacture. If you have any suggestions, I am open to reading them.
Thank you very much
Dave (CA)
PostPosted: Wed Jan 23, 2019 8:14 pm
You mentioned strap -- just one. Take a close look and make sure the strap isn't torn where you fasten it. When you install it, make sure it is fully on over the "nub". If it is just on one strap and nothing else seems to cause it, trying swapping straps. If an undamaged strap is properly installed, it usually take a deliberate action to remove it.
If all else fails, it wouldn't hurt to try heel straps. Instructions are at the top of the post. 8)
PostPosted: Thu Jan 24, 2019 10:18 am
Originally it was my right foot, but my left is also disconnecting as well. First thing I did, was examine the rubber straps to make sure they were not damaged. This craft is brand new December 2018. The first time I used it, no problem, the second time this issue began.
I will review the above rear strap configuration and maybe just try tackling one of the options. The nylon strap maybe the easiest to try first.
Thank you
Dave
Friant, CA (Lake Millerton)
PostPosted: Thu Jan 24, 2019 6:21 pm
recumbent bikes use heel straps if it has not been mentioned. Prob a pretty good selection available.
