It is currently Thu Mar 23, 2017 3:32 pm
PostPosted: Tue Jul 19, 2011 1:46 pm
oais mirage 2011. steering line for rudder broke. cant find instructions for L shapped control. all instructions are for T shaped. looking for help, in what to do and understanding how it works.
PostPosted: Tue Jul 19, 2011 3:42 pm
Instructions to the lever up / down are in the support area: http://www.hobiecat.com/support/products/kayaks/
Section:
Twist and Stow Rudder / Lever Up-Down
Items:
Rudder Manual - Lever Up-Down PDF (295 KB)
Lever Up-Down (Internal Hull) line diagram (127 KB)
Twist and Stow (Up / Down Lever Style) Use and Adjustments
"Up-Bungee" replacement Adventure PDF (131 KB)
"Up-Bungee" replacement Outfitter PDF (126 KB)
http://2010.archive.hobiecat.com/support/pdfs/TwistStowManual.pdf
PostPosted: Thu Jul 21, 2011 6:02 am
I need instructions for a tandem 2011, whats online shows a T handle with each line connected to the two dofferent ens of the bar. my kayak has only one end and no diagram on support to see how the model works, apprectiate input
PostPosted: Thu Jul 21, 2011 6:02 pm
Here's the basic steering system: http://2010.archive.hobiecat.com/suppor ... Manual.pdf
The 2011 Oasis should use the same system but with a couple of minor modifications.
1. Two "L" cranks in parallel rather than a single "T" crank. This accomplishes the same thing but with fewer space constraints, allowing a less constricted cockpit.
2. Continuous loop system using a cheek block rather than terminating at the crank. This takes the static tension off the forward crank, compensating for the increased friction of using two handles.
Here are a few pics showing the details:
Looking aft from the cheek block to the forward crank:
Detail of the forward rudder crank:
Close up of the crank showing both attachment points of the rudder line:
Hope that does it for you until Hobie gets their manual updated. 8)
