It is currently Sun Mar 26, 2017 9:55 pm
 Post subject: Back Fin coming loose
PostPosted: Sun Jun 18, 2006 8:57 am
Matt,
The knurled tensioning nut on my back turbo flipper keeps loosening. Each time I go out it seems to loosen about 1/4 inch. If I forget to screw it tight again the fin comes off the shaft. Is there something I can do to keep it tight. I was told that Locktite is not good in salt water.
PostPosted: Sun Jun 18, 2006 6:47 pm
I think Locktite should work fine -- give it a day to cure. You want ot use Locktite blue (in the red tube) in case you want to undo it later.8)
Users browsing this forum: Bing [Bot] and 4 guests
