It is currently Tue Jan 16, 2018 10:59 pm
PostPosted: Mon Apr 09, 2012 8:26 am
I really like the Trax2 cart over the hard-plastic wheeled model, except for using it when the boat's in the water.
The problem I'm having with putting the cart ON, in the water, is that the wheels float, so it's really hard to submerge the cart with one hand and align the scupper posts. Is there some simple trick?
I hate tipping the boat on its side, but seems the only way.
PostPosted: Mon Apr 09, 2012 10:17 am
There was a thread about this awhile back. I think most people were saying they fill the tires partly with water.
PostPosted: Mon Apr 09, 2012 1:35 pm
I use two hands, get cart under hull, as long as you start one post in scupper hole the other one should align itself in. Just be sure they're both fully in before putting the weight of the kayak on the cart.
Bob
Proud member Kayak Fishing Association of New York
Supporting member NEKF, Supporting member Team Jinx
KW's KFA Team 3
PostPosted: Tue Apr 10, 2012 3:19 am
Hi stk,
Yes there is a trick to using the trax 2 wheels.
I had the same problem until I found out that if you twist the black hub knob
a quarter turn, this releases the wheel assembly from the axle.
with the "near side" wheel removed, it is easy to fit the cart with one hand, then you can just "click" the "near side" wheel back on. :)
Montedane.
PostPosted: Tue Apr 10, 2012 5:06 am
montedane wrote:
Hi stk,
Montedane.
Thanks, Montedane! Sounds like an excellent idea and can't wait to try that, (though the idea of weighting the wheels with a bit of water is also interesting).
Bob -- it's very hard to use two hands to insert the cart, because the winds and tides where I launch usually require one hand to hold the boat.
PostPosted: Sun Apr 15, 2012 7:47 pm
I'll second what montedane said. I also have the trax2 cart and that's the way I do it.
Eric
2013 Caribbean Blue Outback
