It is currently Sat Jan 20, 2018 8:24 pm
 Post subject: paddle holder
PostPosted: Thu May 03, 2012 9:23 am
How did honor connect the holder to the paddle itself on the PA12? Have BB paddle that is fiberglass and would like to do that for my PA14.
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
 Post subject: Re: paddle holder
PostPosted: Thu May 03, 2012 10:32 am
Hobie Tech / Moderator
You can use a Scotty paddle clip #136 (that is what is coming as standard equipment on the new PA12) you can then clip your paddle onto the grab handles on the side (PA 14 would work the same as the 12)
PostPosted: Thu May 03, 2012 11:12 am
Understand, put how did you attached it to the fiberglass paddle?
Steve Valerga Jr.
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Thu May 03, 2012 11:51 am
2 ways - you can screw it onto the paddle and clip it onto the handle - or screw it onto the handle and clip the paddle into it - it works either way. (we are going with the clip attached to the paddle for the PA12 so that you have more freedom of location and it wan rotate around)- if it were mounted directly to the arm you are kind-of locked in to where it will sit.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Thu May 03, 2012 12:49 pm
Thank you very much, I will drill a pilot hole and use a course/ wood screw. Or did hobie use the rubber set nuts they came with the holder?
Steve Valerga Jr.
1988-92
2012 Pro Angler
Take a kid fishing!
