It is currently Thu Mar 23, 2017 8:39 am
PostPosted: Thu Aug 23, 2012 4:59 pm
I would like to find a tandem trailer for 2 side by side
kayaks. One Outback 33" and one 30" wide Ocean Kayak Scrambler
Hobie recommends that the Outback be trailered upside down
which would preclude the use of rubber cradles.
Hobie likes Trailex but I am leaning towards Malone
Does anyone have any recommendations?
2 kayaks 63" total with some room between
thanks
PostPosted: Fri Aug 24, 2012 8:11 am
Hobie Tech / Moderator
I tried the search feature at the top of the page here - and searched 'Malone' and found 10 pages worth of results - maybe look through some posts which have already discussed the pros and cons of the Malone vs Trailex and get some more info - I'm sure other's will reply to this post as well - here's the results - click this link: search.php?keywords=malone&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Fri Aug 24, 2012 8:29 am
Both are more than adequate and very nice trailers. All are oversprung for the weight of these kayaks. One of the trailex models isn't sprung at all - it is for all intents and purposes a solid axle bolted to the trailer frame with only a layer of rubber as an insulator/suspension.
I just installed an Al-Ko torsion axle under one of these (Trailex) and now it's a sweetheart. My kayaks enjoy a smoother ride than I do.
If you're not going to be backing your trailer down into the water, I'd get a Rack and Roll. The coil-over independent suspension is the best thing going for kayak transportation.
PostPosted: Sat Aug 25, 2012 8:22 am
We have a Malone Sport for our Oasis, and it is basically bullet proof with bigger tires and buddy bearings. I had to replace the 2" mount as the one that came with the trailer was a piece of junk. No big deal.
If the Thule Hullavator of today had been on the market, I would have bought one of them.
Backing a light trailer with a long tongue down a ramp can be difficult for me as I can't see the yak or trailer from my Ridgeline. Then you have to deal with the straps after you unload and then load the yak on the trailer. Then you have to have a license fee and get tax again and again in California. Then you have to insure your trailer.
Last but not least, your trailer takes up driveway space.
On our recent trip to our local river, while we were messing with the straps and getting our Oasis in the river from the launch site. A yakker drove down frontward on the ramp. He put his front tires at the last dry line on the launch. Then, he and his friend got out and unloaded a 13' Ocean Kayak on each side of the vehicle from the two Hullavotors.
They piled their gear on the dry part of the ramp, and the driver drove back to the parking lot, parked and walked back down. While he was doing that, his friend loaded both yaks with their gear. When the driver got back down, the yaks were loaded and they shoved off. Meanwhile my wife and I were still messing around with our straps. Then, I had to find a parking spot for my truck and trailer, which can be hard sometimes. The Hullavator guy just pulled into the nearest normal parking space. Some of our launch sites/ramps don't have parking spaces for vehicles with trailers. You have to find a spot on the road to park and hope everything is there when you get back. On a recent trip, someone cut off the vehicle electrical connection from the trailer.
REI is having a great sale on Hullavators. You could buy two Hullavators and the cross bars and vehicle mounts for basically what a good trailer would cost.
When you aren't using the Hullavators like in the winter, you can take the Hullavator off and the crossbars and their mounts and store them in your garage.
Current but short time REI sale on Hullavators:
http://www.rei.com/product/723901/thule ... ideo-inner
thanks
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Sat Aug 25, 2012 3:15 pm
I have the Rack N Roll and is a very nice set up. will handle two side by side. I use the malone seawings to hold the outback and just the bars for the PA 14. I used the old stand by with pool noodles on the bars to pad the PA 14. Works for me and does not deform the bottom of the yak. Good Luck.
PostPosted: Sun Aug 26, 2012 4:38 pm
I have the cheapest Trailex with and Adventure on the bottom with a Outback on the top and it works for me.
I'm right 98% of the time. The other 3% I don't worry about.
Users browsing this forum: NH_HobiePA14 and 5 guests
