It is currently Wed Jun 28, 2017 5:53 am
PostPosted: Sun Nov 11, 2012 8:59 pm
I need to mount a RAM Mount base in the forward "tray" area; between the rudder down handle and the kayak carry handle.
Problem is when I feel inside the hull there isn't direct access to the "tray" surface.. feels like a block on underside.
Any recommendations on how to mount a RAM Mount base to this area, it will hold the Evolve motor control so it won't be roughed up. I'll also need to drill a hole for the power cable next to it also.
PostPosted: Mon Nov 12, 2012 8:27 am
I have a 2011 Outback and mounted the new YAKATTACK gearTrac in one and a mighty mount in the other. No issues whatsoever. You should be able to use a mirror and look up under there. Perhaps you have some "styrofoam" floats or something jammed uner there?
PostPosted: Wed Dec 12, 2012 7:33 pm
See my Youtube video showing my Outback with Evolve throttle control mounting position: http://youtu.be/bVdEx17CdXw
