http://www.hobie.com/forums/
Drive mast stuck in sprocket
http://www.hobie.com/forums/viewtopic.php?f=11&t=46366
Page 1 of 1
Author:  jpeight [ Sun Jan 27, 2013 2:52 pm ]
Post subject:  Drive mast stuck in sprocket
Hi - Quick question on the V2 sprocket. I have a bent mast stuck in the sprocket hole. In trying to loosen it, I managed to loosen the brass insert in the sprocket itself - now the whole assembly (mast and insert) spins inside the sprocket.
I can replace the sprocket, but thought I'd see if there are any ways to salvage this. Next time I'll try a little heat before I turn the wrench...
Author:  KayakingBob [ Sun Jan 27, 2013 3:33 pm ]
Post subject:  Re: Drive mast stuck in sprocket
Time for a new sprocket! Sometimes they use a bit too much Loctite on them at the factory :o
http://www.phpbb.com/
