It is currently Fri Dec 15, 2017 2:59 pm
 Post subject: getting wet
PostPosted: Wed Jul 04, 2012 12:26 pm
which hobies will keep me the driest, I was thinking about an outback or revo for inshore and off shore for king fishing.
 Post subject: Re: getting wet
PostPosted: Fri Jul 06, 2012 6:53 am
Outback by far.
PostPosted: Fri Jul 06, 2012 7:25 am
The Outback has more width and more freeboard. Not sure it'll keep you 100% dry, but it is drier than the Revolution in most conditions.
PostPosted: Fri Jul 06, 2012 7:41 am
Take a look at roadrunners reply in the post titled "how dry is a revo 11'?
Good information there on the outback, revo, and revo 11.
Baitman and Sabiki
2012 Oasis
PostPosted: Fri Jul 06, 2012 9:43 am
The best advice I got in putting my toe in the water of this sport, that was new to me, was to test drive boats. Find some of the big rental stores who also sell Hobie and they're likely to let you try out a few models. Do it in the same conditions.
Also, consider 1) Your particular body size and 2) How you'll use the boat day-in-dayout (tooling around, fishing, sailing).
For example, there really is a difference between the Revo' 11 and 13 in tippyness depending on YOUR size. Some boats are totally fishing platforms or "SUVs" as opposed to yak's that cruise better, but may splash a little bit more.
Drive 'em.
PostPosted: Thu Jul 12, 2012 9:01 am
Outback :)
Jacques Lebaz
Owner
http://www.MiamiCatamarans.com
The #1 place to rent HobieCats in Miami!
PostPosted: Thu Jul 12, 2012 10:10 am
I have a few boats, but one of my favorites for dryness are the i12's. Very very stable and super dry because of the design. They are a bit slower, but you can stand up in them and they are really stable.
"Never mistake a clear view for a short journey." - Cowboy Proverb
Graduating from adventure junkie to dealer. Get your fix at http://www.fasterfarther.com
PostPosted: Thu Jul 12, 2012 8:21 pm
My Outback is the driest yak I have ever owned - [u][b]except [u][when you are headed into wind chop when it can kick up plenty of spray. Otherwise I have a dry seat at all times, (I am 5" 10" and weigh 200lbs).
PostPosted: Fri Jul 13, 2012 8:36 am
Besides launching or landing most yaks, you can get wet feet and a wet butt while on/in the water.
So buy or keep the yak you like and buy a pair of Kokatat Tempest Pants w/ socks to wear while yaking or fishing and yaking.
If you want to start early in the season and then extend your yaking season in the fall early winter. This is the way to go. Your feet, ankles and lower legs stay warm and dry as the rest of your body waist down. No more wet butts and wet/cold feet when we wear our K's.
Some evil genius must have designed other Kayak pants without attached waterproof socks/feet. If your feet get wet while launching a yak, they will stay wet/cold the rest of the trip. So we went to the Kokatat Tempest Pants with the built in feet/socks.
Unless you have worn these before, you probably should go to a store which sells these Kayak Pants with w/feet. Then have one of their good people help you to find the right size. After finding the K's that fit, you should try various sandals or boots to see which ones fit. I knew my fly fishing Korker Boots at home would fit and they did. I now use the Korker wading sandals.
My wife couldn't find a comfortable fit, and the Clavey sales rep suggested taking them to a shoe store or Big 5 and try on various feet gear. She took the kayak pants to a big 5 and found a sandal that fit over the K's socks with her feet in them.
At that time we only owned a Hobie Oasis, and we knew that that our feet with her bigger sandals or my Korkers would not fit into the foot strap/strirups of the Hobie Mirage Pedals. So we took off the foot straps on the Mirage Pedals. It took us about 30 seconds to learn to use the Mirage Pedals without straps, and we haven't used the straps since then.
My wife puts on her Kokatat Pants at home and leaves them on until we get back home. I don't want to drive with my Korker big Footprints, so I put the Kokatats and Korkers on at the launch site and remove then after we get the Oasis back on its trailer. Or my Freedom Hawks back in my truck bed. When I yak/fish with my Freedom Hawks. I put the Kokatats on before I get into either yak. With the Freedomn Hawks, I do a standup entrance with one boot in the yak while holding the grab bar, and I use my oar to steady me in the water with my left foot in the water. Then, I shove off and step into the yak.
This brings some water into the yak, but I'm dry due to the Kokatats. With our Oasis, my wife gets in while I steady it. Then, I move the Oasis up with my vacant seat next to me, steady myself with an oar, straddle the yak and sit down and shove off. Either way with the K's I'm dry and warm. Without the Kokataks, my feet/socks/footgear would be wet and cold for the trip.
I 'launched' my new Freedom Hawk Pathfinder this way in the last week of February. I stayed dry and warm while other yakkers got wet feet and often wet butts. The air and water temp was in the 40's, and I was warm and dry.
I own several fly fishing waders, and the Kokatats have become my waders of choice when fishing Doran Beach and other areas where I don't have to wade deep as they are so easy to put on and take off. If I decide to beach my Freedom Hawks and wade and cast from the shore of a river or lake, the Kokatats work great as I step from the yaks onto the beach and back on the yaks.
Launching or bringing in the Oasis without the Kokatats can be a wet and cold time. The K's eliminate that problem. We use various Goretex and non Goretex jackets with our K's, which is an advantage over more expensive one piece Kayak suits. My wife might put in up to 3 tops into her storage area by her on our Oasis to stay comfortable throughout the trip. As the weather and temps change on our yak trips, we can change our clothing tops and our feet and butts stay dry with the Kokatats on.
Since I have 3 yaks, I keep my Kokatats, my life preservers, hats, gloves and jackets in the trunk of my Ridgeline. That way they are right there when I get ready to put the yak off the day in the water.
So find the yak or yaks you like or love, and then buy a pair of Kokatat Tempest Pants w/ socks/feet to stay dry and warm. Since they breath, it has to be a day over 95 degrees before I get uncomfortable.
The link below will take you to reviews by other yakkers:
http://www.campmor.com/kokatat-tempest- ... ader-76062
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Fri Jul 13, 2012 9:23 am
Here's a short answer; the Outback is a drier boat than the Revo.
Southwest Hobie Island Club
PostPosted: Sat Jul 14, 2012 7:18 pm
sounds like I need to get the revo 11 or 13, not sure which one yet, my buddy says I need the 13 to fish for kings off the beach, what do you all think? Thanks for the great imfo on the yak pants.
PostPosted: Mon Feb 11, 2013 11:11 am
HI I just came across this and was wandering if I would be able use my Korkers wading boots with the hobie mirage drive as they are really bulky. Whic Korkers to you have? I have the Metalheads I believe so was wander if they were two clunky. I have the Kokatat Pants with booties as well. I just got the Revolution 11 but haven't taken it out yet as there is still ice on the water :(
Cheers
Greg
PostPosted: Mon Feb 11, 2013 3:41 pm
I think the question is wrong. Should be:
Which Hobie is the least wettest? :D :D
I don't think anyone will keep you dry...
br thomas
PostPosted: Mon Feb 11, 2013 7:53 pm
I have both the outback and revo. The outback is drier by far
PostPosted: Mon Feb 11, 2013 8:24 pm
Outback is dryer than the Revo. Quick answer.
