It is currently Fri Dec 15, 2017 10:51 pm
 Post subject: Serial numbers?
PostPosted: Sun May 12, 2013 6:10 am
Just baught and old style hobie outback and want to no info about it.
Where is the serial number on those?
The seat is done
Have to change all bungee cord
Tune up on the mirage drive
Change the cord to the back rudder both side
Seem to be some kind off something under the masss hole under the hull....mmmm will have to look at this.
The mirage drive hole seems to be low in the hull,,,,look like below water line,,,is there water that will acumulate
there?
Joco
 Post subject: Re: Serial numbers?
PostPosted: Sun May 12, 2013 5:35 pm
Right rear should have the serial numbers.
PostPosted: Tue May 14, 2013 6:33 am
When I use the outback I put my cooler with drinks in the front. I weigh 200lb and the water just barely comes into the yak. Just my heels get wet.
Jim
