It is currently Mon Jan 22, 2018 11:06 pm
PostPosted: Fri Dec 27, 2013 2:52 pm
I have an outback kayak.
When I want to go faster or peddling against a current I hold on to the mid boat carrying handle. After a couple of hours, my right wrist starts to ache because of the angle of the handle.
Does anyone know of an adjustment/addition that can be made to that handle to alleviate the pressure on the wrist ?
PostPosted: Sat Dec 28, 2013 8:26 am
Install turbo fins and make sure your seat back adjustment straps are not slipping and that is causing you to be leaning back/aft too much.
It sounds like you are holding on to the carrying handles because you are leaning to far backwards.....yes?
I found that my seat back, plastic "strap slide adjuster" did not fully secure the strap and they would slip, causing me to lean back/aft too far.....I solved the problem by tying a " 1/2 knot slip loop" with the tail end of the strap so it would stop against the slide adjuster. That prevented the strap to no longer slip in the adjuster.
If I wanted to adjust the seat back position, I simply pulled on the tail end of the strap and it would come undone for seat back repositioning....then re-tie the 1/2 slip knot again.
Think of tying a 1/2 bow knot in your shoe lace....that is the knot I am trying to describe,....click on http://www.southee.com/Knots/Knots_Miscellaneous.htm and scroll down to #22 or ABOK #529
This simple solution worked for me :idea:
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Wed Jan 08, 2014 12:23 am
You can try these -- put them wherever you like: viewtopic.php?f=11&t=44559&p=188665&hilit=#p188665
Or these (install them on pad-eyes anywhere): viewtopic.php?f=11&t=9077&p=46577&hilit=#p46577
8)
Users browsing this forum: Bing [Bot] and 4 guests
