It is currently Wed Apr 24, 2024 9:08 pm
 Post subject: Outback rudder issue
PostPosted: Wed Aug 06, 2014 5:57 pm
I recently purchased a used Hobie Outback. The first time I took it out I discovered it only turned left and hard left. Below are pics of the steering and rudder. I'm not familar with Hobies so any suggestions to what's the problem is greatly appreciated .
 Post subject: Re: Outback rudder issue
PostPosted: Thu Aug 07, 2014 8:34 am
First... the stainless mount is bent off to the left.
Bend it straight and then adjust steering lines while steering handle is centered in it's throw. That is pointed to the right at about 20 degrees or so. Swing the handle left and right... to find the center... not to be pointed straight ahead... when the rudder is centered.
PostPosted: Thu Aug 07, 2014 8:35 am
The rudder mount is bent. The rudder should be vertical - not at an angle. You might just bend it back into shape - or if needed you can buy a replacement mount part # 81350001 from any Hobie kayak dealer - to find a dealer click the link at the top of this page or here: http://www.hobiecat.com/dealers/
Jacques Bernier
http://www.hobie.com/
PostPosted: Thu Aug 07, 2014 5:20 pm
Thanks for the help.I bent it back.
I'm also thinking about taking off some of the existing mounts and installing gear tracs. Any suggestions?
