This is an update on setting up my 2014 AI to sail with the standard sail but without the amas/akas.
I've been experimenting with and without the lightweight boom I attached to the sail/ mast with Prusik knots. Without the boom the yak is much harder ro manage when reaching or downwind. As the sail fills/sags the centre of pressure moves so much that the yak becomes quite difficult to control, especially when running downwind in following seas.
With the boom fitted, I was having problems with the boom lifting downwind, resulting in similar (albeit less marked) control problems to having no boom at all. So I changed the routing of the mainsheet in order to control boom lift better when running downwind or broad reaching.
Now, the mainsheet end is first knotted to a pulley (A) at the aft end of the boom, then the mainsheet goes down through another pulley (B) on a short rope traveller located at the aft end of the cargo bay before coming back up through the aft boom pulley (A). This gives a 2:1 reduction.
The mainsheet then runs forward along (under) the boom through another boom mounted pulley (C), which I can slide along the boom to position it as I wish (with another Prusik knot).
Then, and most importantly, the mainsheet goes down through a final pulley (D) attached with a thin rope loop to a rope traveller that is tied across the yak to the back of front ama X-bar. The mainsheet then comes back into the cockpit area.
When running downwind or broad reaching, I keep the mainsheet outboard of the pedals by pushing pulley D right across the front traveller to the leeward side. Most importantly, I also move pulley C forward along the boom so that it lies directly above pulley D, meaning the mainsheet runs down almost vertically between pulley C and pulley D (photo below) This works surprisingly well as a pseudo-vang to control boom lift, with a marked increase in speed when running downwind or broad reaching, as measured by GPS. The sail and therefore the yak is now much more stable in gusts too.
When close hauled or reaching, I pull pulley C back along the boom so there is just the mainsheet running down between the peddles to pulley D (riding centrally on the front traveller - see photo below) and back to my right hand. If I left pulley C in the forward position it would catch on the peddles
Compared with the standard mainsheet routing, the other advantage of this set up when heeling is that I'm no longer sitting on and therefore blocking the mainsheet with my bum when hiking out on the starboard side (that was exciting the first time it happened!).
I've also now fitted proper dinghy style longitudinal hiking straps (visible in the photo below), which mean I can now sit straight legged across the yak when hiking out. Top speed in the same wind conditions (10 -13 knots est.) when reaching has gone up as a result and is now much more easily/comfortably/securely acheived. I haven't quite broken the 7 knot barrier on a reach but I'm getting close, with weak abdominal muscles being the current limitation
( I have seen just over 5 knots downwind though)
The real surpise for me with the above set up is how forgiving it is. I've been knocked down to around 45 degrees in gusts (before I could let out the mainsheet). The roll is nice and slow and controllable and the yak just bounces back up. This set up is actually more controllable than with my aftermarket 35 square foot sail with boom and vang, which was totally unexpected. I think it's proabably due to the 'give' in the sail roach and the thin boom.
I've also sealed the Hobie mast with silicon at each end and teflon plumbers tape at the join to help ensure it stays buoyant if I capsize, but so far I haven't capsized once with the new set up (as opposed to the 3 or 4 times before), despite going out in what were sometimes worse conditions, particularly downwind
I also had to glue up the telescopic fishing rod based boom, as with the compression loads resulting from the new mainsheet set up it was collapsing (not fun). You can actually see the boom flexing slightly in the above photo.
Loads of fun
