It is currently Sat Feb 22, 2020 10:03 pm
 Post subject: Storing an Outback
PostPosted: Wed Jul 12, 2017 11:07 am
With little room in my garage I was wondering if it's okay to store an Outback on its scupper wheels with a foam pad under the nose?
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
 Post subject: Re: Storing an Outback
PostPosted: Wed Jul 12, 2017 4:53 pm
No, It will bend, and risk damage to scupper holes. Best invert it sitting the side rails on some cross supports. If you want to install upright due to fit out then needs to be on weight spreading cradle or rails, to prevent bottom flattening.
ideally shouldn't be left on trolley for no more than an hour or two, especially in hot weather.
PostPosted: Wed Jul 12, 2017 6:54 pm
Thanks.I may rig some saw horses with PVC pipe to spread the weight for upright storage.
PostPosted: Fri Jul 21, 2017 10:39 am
Hobie Fish Tech / Moderator
Upside down on the padded sawhorses is ideal.
Howie Strech
Associate Product Manager - Fishing Accessories
PostPosted: Fri Jul 21, 2017 12:31 pm
Is it good to store a Pro Angler upside down on padded saw horses too?
PostPosted: Fri Jul 21, 2017 12:53 pm
As long as the kayak is not resting on the H-Rails, you'd be fine doing this. With the weight of the PA it's not recommended to store on the rails. Best option is on cradles, otherwise you can store on foam pads on the floor. The owner's manual has suggested methods of storing:
Howie Strech
PostPosted: Wed Aug 30, 2017 2:34 am
What is the spacing for setting a Outback on 3" PVC PLASTIC PIPE
PostPosted: Fri Sep 08, 2017 3:42 pm
Hmm still looking answer for this
PostPosted: Fri Sep 08, 2017 8:37 pm
Best answer is to rotate your outback so the bottom is facing up and then lay the PVC pipes into the two hull slots......make a measurement and the task is complete. :idea:
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Wed Sep 20, 2017 7:11 pm
Here is how I store my HOBIE OUTBACK in the garage
[youtube]/mEK-0wayt3k[/youtube]
https://youtu.be/mEK-0wayt3k
let me know if you have any questions on the set up
PostPosted: Thu Sep 21, 2017 7:24 pm
How about if I just turn my Hobie Outback upside down on the carpeted floor of the garage?
PostPosted: Sat Oct 14, 2017 9:29 pm
^ Bump
PostPosted: Sun Oct 15, 2017 2:37 pm
I don’t know if it would sit flat on the floor, but you could cut a few 2X4’s to run from side to side where the rod holders are moulded into the kayak. This would keep it just off the floor and keep it from warping.
PostPosted: Fri May 04, 2018 3:34 am
I've just got a new Outback Camo. Are Hobie really saying that keeping a kayak on its side on thick rubber matts (not hard ground) in a cool garage will deform the hull/sides/shape?
If so I kinda regret buying it if they are so structurally weak / too heavy for the plastic it is made from.
