It is currently Tue Apr 23, 2024 11:16 am
 Post subject: V1 TO V2 TURBO ON 180
PostPosted: Sat Dec 16, 2017 11:31 am
So I bought a set of v2 turbo fins for my 180 drive. Any reason why I can't use the original rod masts? There is only about an 1 1/2" difference.
PostPosted: Sun Dec 17, 2017 10:39 pm
If you bought Turbofins you need Turbo masts. If using V-2 fins, then V-2 masts would be best. "Standard" masts are too short for Turbos, allowing the leading edge tips to flop around. This will reduce the performance of the fins and possibly damage the fins in the long run. If you can't get the long masts now, it's best to use standard fins and masts until you can get a set. 8)
PostPosted: Mon Dec 18, 2017 8:20 am
There is a kit that does the upgrade which includes masts. If your drive is a bit older (before last spring)?... you could use the V1 to V2 Turbo kit which comes with the new style fins and the new booms.
V2
V2 Turbo Fin Kit
72067002 ST-TURBO V2 FIN KIT MD180 BK/GR
If V1 to V2 Turbo Upgrade use:
81501112 MD180 V2 BOOM-MAST-TURBO FIN KIT
PostPosted: Mon Dec 18, 2017 3:22 pm
Well I slipped the turbos onto the standard mast and I can't move the leading edge more than an 1/8" in the area where there is no mast. I think I will give it a test run when I get a chance. I got the turbo fins for just over $80 on ebay. New masts would be another $50.
I will let you know how things work out.
PostPosted: Mon Dec 18, 2017 6:35 pm
You could also try putting a 1 1/2" long plug (1/4 or 5/16" dowel) in the bottom of the fin to see if it makes a difference -- either way I think it will be an improvement over standard fins. IMO, you won't get the full potential of the Turbos at the higher speeds, and they will eventually crack at the tip of the existing mast due to flexing (depending on how hard you use them). It's sure worth a try though!. I'm looking forward to your results! 8)
PS. If you put a plug in one side (allowing about 1/4" gap for the fin to wind up) and try the Drive, you can test whether the plug helps. If the plug improves performance, that fin will have more thrust, making the boat rock slightly as you pedal. If the boat doesn't rock, then the plug probably didn't make a difference. :wink:
PSPS. I'm sure you realize that the V-2 fins attach to V-2 booms, so if you are changing from V-1 to V-2, presumably you got new booms with your fins.
PostPosted: Thu Dec 21, 2017 9:24 am
I got the older set of the standard fins when I got the outback and did a warranty return for the pulls and the fins. Both got upgraded.
Not sure when I will get back out but I will let you know how it goes.
PostPosted: Thu Mar 15, 2018 6:43 am
Well I finally got out and the fins worked flawlessly. When I got out I checked them and found no defects. Glad I saved my money.
PostPosted: Tue Mar 20, 2018 4:44 pm
The V1 to V2 is a free upgrade.
PostPosted: Tue May 08, 2018 10:53 am
I bought a new Hobie Sport last May. Does it qualify for the free upgrade?
Thanks.
PostPosted: Sun Nov 10, 2019 6:05 am
Thanks.
I wish you would have answered my question. Now it's too late, and my drive is trash.
