It is currently Wed Jan 23, 2019 3:25 am
PostPosted: Wed Apr 11, 2018 8:09 am
I am looking for suggestions for plastic material and color matching tips/tricks for soldering screw holes in my Orange Mirage Outback. I had a long H-Rail on there, but am taking it off, shortening it, and installing a Boone Dox. There are now 2 big screw holes from the H-Rail that I need to fill in. I do have a soldering iron and have seen some videos on how to patch the holes, but wanted some input on the material to use and how to try to color match. I was actually recommended from the Hobie Facebook group to reach out in the forums to see if anyone had suggestions for me. Thanks!
PostPosted: Wed Apr 11, 2018 5:24 pm
There are a couple of options. Hobie currently has plastic welding rod available at no charge in the various colors. It can be requested through your local dealer (who may or may not know about it). Otherwise or until then, you can just put screws in the holes with a dab of clear silicone calk to seal them (optional). This will make them look neat and keep the holes available for some possible future use!
If you're welding holes, you can use any matching plastic strip (about 1/8" across). Melt the tip with a lighter and dab it into the hole; quickly flatten it out with a putty knife or flat blade. Practice first till you get the hang of it! 8)
PS: When ordering the free welding rod, provide the year model as well as the color for best color match. The colors change slightly over the years so an exact match is not always possible. They can at least get you close to your original color.
PostPosted: Thu Apr 12, 2018 9:54 am
Hobie Fish Tech / Moderator
Here's the KC Plastic weld tool:
72097001
KC WELDER PRO WITH ROD STOCK
Howie Strech
Associate Product Manager - Fishing Accessories
Users browsing this forum: Google [Bot] and 1 guest
