It is currently Sun Aug 25, 2019 9:09 pm
PostPosted: Thu May 03, 2018 11:59 am
I currently have an Oasis with Hobie Sidekick amas installed behind the rear seat. I would really like to add Boondox Landing Gear as well. The take everything off and roll the kayak on its side to install cart thing is getting old. I would only use the Boonedox to get to and from the water and would not leave the wheels installed while on the water. Conversely, I have no need for the amas on land. So an ideal solution for me would be one single mount that can be used with Boondox or amas. Has anyone fashioned an adapter or made changes to accommodate using Hobie's Sidekick (or another company's) amas with the Boonedox Landing Gear mount?
Peter
PostPosted: Thu May 03, 2018 3:45 pm
Boonedox landing gear would be a lot easier but have you considered wheels that don`t float?
PostPosted: Thu May 03, 2018 6:08 pm
I think it's a great idea as looking as the boonedox tubes cam fit in the side kick bar, you're golden.
PostPosted: Thu May 03, 2018 8:12 pm
Much of my kayaking is off sandy beaches with light to moderate surf, sometimes alone and sometimes the two of us. I would not want to try and install or remove the cart while in the water due to surf. I use the heavy duty cart with beach tires now to transport from trailer or cottage to water and back but wheels are left onshore. I can lift and shift the back of the Oasis to remove the cart but have to lean it over on the side to insert the cart.
Just seems tilting the kayak only a little for the Boonedox would be a lot easier and if I could attach the amas to the Boonedox mount (wheels removed and amas installed before lauching, amas removed and wheels installed after beaching) I would only need one mount.
Peter
PostPosted: Thu May 03, 2018 9:38 pm
Just watched a Boonedox video and it looks like you could just insert the sidekick tube into the boonedox mount. Drill holes at 3,12,and 9-o-clock in the sidekick tube and use the thumb screw to obtain the three different height positions. (12-o-clock being the mid or level position) If needed, I found that the center post from a crutch fits inside the sidekick tube. https://imgur.com/ss5SOYb I like your idea.
PostPosted: Fri May 04, 2018 9:04 pm
Would really like to see this , I have Boonedox Landing gear on a Outback seems doable
PostPosted: Mon May 07, 2018 7:38 am
I just looked at mine (boonedox and sidekicks) - all you would need to do is drill a hole on each side of the sidekick tubing and use a 2" T-Bolt to attach it on the top of the Boonedox.
The sidekick tubes do not fit into the Boonedox- not even close...
